SohCho
May 24, 2020Aspirant
ORBI RBR50
Hi All, need some help here. I am trying to split the 2.4Ghz and 5Ghz channels. I telnet into the router and successfully am able to do this. After the router reboots I can see the 5GHz channel. ...
CrimpOn
May 24, 2020Guru - Experienced User
There are some really long posts about splitting the SSID's. Buried in them (somewhere) are discussions about how to make the change "persist". Good luck finding the right one.
If it's not too personal, would you share the reason for wanting to do this?
SohCho
When I use a device in a specific room in a corner of my house in the basement of always connect using 2.4GHz with really weak signal and sometimes even dropping. I don't know why it won't switch over to the 5GHz band. If I separate these then I can atleast explicitly use the 5GHz channel.
- CrimpOnMay 24, 2020Guru - Experienced UserConventional thinking is the 5G signals do not propogate as far as 2.4G signals, so trying to connect at 5G when 2.4G is weak is doomed.
One easy test is to use a WiFi signal Analyzer app on Windows or Android to look at the signal strength of the Orbi channels. The Orbi SSID should appear two times for each Orbi unit. (once on a 2.4G channel and once on a 5G channel). It might be worth a few minutes to confirm that the assumption of 5G being "better" is correct.
Is it only one device that does this? Do other devices connect automatically at 5G?- SohChoMay 24, 2020AspirantYes, I tested with multiple devices and same result. Also tested with another router and 5GHz works just fine. Just not 2.4FHz.
This only happens in this specific corner of the house, which also unfortunately happens to be my home office too.- CrimpOnMay 24, 2020Guru - Experienced User
Hmmm. Did the other router have exactly the same SSID/password as the Orbi?
The reason I ask is my cell phone is "willful". If I tell Orbi to stop "Broadcasting" the 5G SSID. Disconnect from Orbi and then reconnect, the phone goes right back on 5G. I have to not only disconnect, but "forget" the Orbi. Then I search for WiFi and the phone finds the 2.4G SSID and connects.
I wonder, has this device "forgotten" the Orbi SSID and then searched for WiFi again?
- michaelkenwardMay 25, 2020Guru - Experienced User
CrimpOn wrote:
Conventional thinking is the 5G signals do not propogate as far as 2.4G signals...I thought it was more a case of the laws of physics rather than "thinking".
