APS007
Jun 07, 2020Aspirant
ORBI RBR50
I have just installed and all seems to be working, except by devices say No Internet Access even though there is and it is working. Anybody else seen this, and how do I get to make the devices repor...
Jun 07, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What devices do you have connected?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
- APS007Jun 08, 2020Aspirant
Hi
Lots of questions, I’ll do my best.
The firmware is V2.5.1.16
The Internet service is via Vodafone and I have plugged the Orbi into a spare port on the Vodafone router as per the Netgear instructions. The Orbi has an IP address of 192.168.1.12. The devices connected to the Orbi include Windows laptops, IMacs, iPhones, iPads, a Nest hub, Android tablet and several Kindles. All get 10.0.0.x addresses.
They all connect but the PC reports no internet connection but it works. The Android device shows half of the Wi-Fi symbol with a ! mark and reports no internet in the settings, but works.
If I plug in a device to either Orbi on a cable no problem..
I have got good reception around the cottage so no worries there.
Please advise
Thanks
Andy
Hi, Just found how to switch to AP mode, problem solved..
Thanks for the hint.
Andy
- FURRYe38Jun 08, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopGlad you got it working.
Please mark your thread and solved so others will know.
Enjoy. :smileywink:
