Pat64's avatar
Pat64
Guide
Jun 27, 2020
Orbi RBR50
Hello,
I have a router Orbi RBR50 and I would like to desactivate the 2,4 g to only get the 5g
I do not see how to proceed !
Can some assist ? Many thanks
Patrick
  • CrimpOn's avatar
    CrimpOn
    Some explanation of the purpose would help.  What is this intended to achieve?
    The Orbi web interface, Advanced Tab, Advanced Settings, Wireless Settings provides control over the Transmit Power, which can be dropped to 25%. Completely disabling either of the two WiFi channels is not supported in the regular Orbi controls.
  • FURRYe38's avatar
    Netgear provides a simple mechanism to accomplish this:
    Log into the Orbi web interface (http://orbilogin.net)
    Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
    Uncheck the box, "Broadcast SSID on 2.4G or 5G"
    Click "Apply"
    All devices that are currently connected to the Orbi will remain connected.
    On the smartphone, go to wireless settings and "forget" the Orbi SSID
    Search for available WiFi networks. Select the Orbi WiFi. Enter the password. and connect.
    If you are curious about whether the smartphone is actually connected at 2.4G, you have to wait a few minutes, because the "Attached Devices" display takes a while to update.
    Open the app and set up the 2.4G device.
    Once the device is connected and working as it should, reverse the steps.
    Check the "Broadcast" box and click "Apply"
    "Forget" the Orbi WiFi. Search. Enter password. Connect.
    Pat64 wrote:
    Hello,
    Patrick
