NAMetz
Jan 06, 2021Tutor
Orbi RBR50
Hello community. I have a Macbook device that after some internet outage and rebooting, is not allowing any web pages to be searched. Whether I use Chrome or Safari, any web search ends in "Privacy E...
- Jan 06, 2021
Good to hear. Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed again.
Please mark your thread as solved so others will know.Enjoy. :smileywink:
Jan 06, 2021Guru - Experienced User
Do you have any accesss controls enabled on the RBR? Armor or Circle?
