WDLuisi
May 11, 2021Aspirant
Orbi RBR50
Is there a way delete multiple devices from the device manager? I rent my property and have a guest network. Every time I have a renter all of their devices get added. The app only allows me to de...
- May 13, 2021While connected to the orbi's wifi, use a browser to connect to the router's IP address. Sign in to the orbi with
Username: admin
and that account's password
You will NOT need to login to your Netgear account.
CrimpOn
May 11, 2021Guru - Experienced User
Despite numerous reboots, my Orbi kept a record of every device that had ever been connected. I had 36 active devices, and 124 devices total. In the web interface, almost 90 devices were in the Access Control table: "Allowed devices that are not currently connecfed". With the web interface, it is quick to delete any that no longer apply. In the "app", it is one-at-a-time. (ugh)
A Factory Reset, of course, wipes out EVERYTHING. For a rental property, this might not be so bad. Hold the reset button down for 10 seconds and everything goes back to the credentials printed on the labe.
