WDLuisi
May 11, 2021Aspirant
Orbi RBR50
Is there a way delete multiple devices from the device manager? I rent my property and have a guest network. Every time I have a renter all of their devices get added. The app only allows me to de...
- May 13, 2021While connected to the orbi's wifi, use a browser to connect to the router's IP address. Sign in to the orbi with
Username: admin
and that account's password
You will NOT need to login to your Netgear account.
WDLuisi
May 13, 2021Aspirant
That's great news thanks. I'm assuming I need to login to my Netgear account. Can you tell me the steps I need to take to do this?
--Chuck
May 13, 2021Guide
Username: admin
Username: admin
- WDLuisiMay 14, 2021Aspirant
THANKS So much. I had manually deleted all the off-line devices before I was lucky enough to get your advise. I did log in as admin to the IP address and saw everything as well as a firmware update to both router and satelites. So thanks again. Just to confirm: Had I not manually deleted those devices, would they have shown at the bottom of the active list? And then I could have selected all of them to delete?
- CrimpOnMay 14, 2021Guru - Experienced User
WDLuisi wrote:Had I not manually deleted those devices, would they have shown at the bottom of the active list? And then I could have selected all of them to delete?
Had you not deleted them, they would appear on the list of "Allowed devices that are not currently connected." There is also a table of Blocked devices thar are not currently connected.
There appears to be a semantic issue with the word "connected". To us ordinary humans, "connected" means attached to the Orbi WiFi and able to communicate. I believe to Netgear, "connected" means "has entered the correct WiFi password and is thus connected. But if it is Blocked, then it cannot communicate (send/receive data packets)." That must be why the top table will sometimes have devices that are Blocked.
- --ChuckMay 14, 2021Guide
Yup. The 3 lists are:
- Allowed or Blocked.devices currently connected
- Allowed devices not currently connected
- Blocked devices not currently connected
The Help Center says:
Access Control Help
You can use Access Control to allow or block computer or electronic devices from accessing your network. When a device is blocked, it would only be able to get an IP address from your router, but it won't be able to communicate with other devices, nor it would be able to connect to the Internet.
