lauriegaines
Oct 31, 2021Tutor
Orbi RBR50
I have been using my Orbi for about 3 years without issue. My wi-fi recently went out and CenturyLink installed a new modem. Ever since they did that, my ORBI has not worked. I have tried plugging...
Oct 31, 2021Guru - Experienced User
what modem did they install?
Centurlylink tends to install modem/router combo devices.
It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
- lauriegainesOct 31, 2021Tutor
Thank you so much for your reply! They installed a Century Link modem with no model name or anything else on it. As for your solutions, I don't think I can do number 1 because I need to be able to use that wi-fi to operate my printer. (The Century Link wi-fi is in my main house, I used the ORbi for my guest houses out back. ) Option 2 might work but I have absolutely no idea how to do what you suggested! I can also try Option 3 but also have no idea how to do that either. There were absolutely no instructions left at all with the new router and the technician did not explain anything to me!
- plemansOct 31, 2021Guru - Experienced User
If you're using the centurylink, option 3 would probably be the easiest for you.
pretty easy to put the orbi in access point mode.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
OK so I tried to figure out how to reconfigure as an access point. But all the instructions say that I have to access the orbilogin.com (to change the setting) through a device that is connected to the Orbi network.....but the problem is that nothing will connect....only my century link router will connect to the internet. I have connected the Orbi internet port and my Century link modem/router LAN port with an ethernet cable but nothing is working. So I am back to square one. This shouldn't be so difficult.....I just want to tear my hair out! What am I missing?
