lauriegaines
Oct 31, 2021Tutor
Orbi RBR50
I have been using my Orbi for about 3 years without issue. My wi-fi recently went out and CenturyLink installed a new modem. Ever since they did that, my ORBI has not worked. I have tried plugging...
Oct 31, 2021Guru - Experienced User
If you're using the centurylink, option 3 would probably be the easiest for you.
pretty easy to put the orbi in access point mode.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
lauriegaines
Oct 31, 2021Tutor
OK so I tried to figure out how to reconfigure as an access point. But all the instructions say that I have to access the orbilogin.com (to change the setting) through a device that is connected to the Orbi network.....but the problem is that nothing will connect....only my century link router will connect to the internet. I have connected the Orbi internet port and my Century link modem/router LAN port with an ethernet cable but nothing is working. So I am back to square one. This shouldn't be so difficult.....I just want to tear my hair out! What am I missing?
- plemansOct 31, 2021Guru - Experienced User
disconnect the orbi from the centurylink device.
then factory reset the orbi. (push and hold reset for 7-15 seconds while its powered on)
then you should be able to connect and go through setup with it disconnected from the centurylink device (other than setting up internet).
Once its setup, you can put it in access point mode.
Once you put it in access point mode, it'll reboot.
Connect the orbi's wan port to the centurylink's lan port
- lauriegainesOct 31, 2021Tutor
disconnect the orbi from the centurylink device. DID THIS.....
then factory reset the orbi. (push and hold reset for 7-15 seconds while its powered on) DID THIS>>>>
then you should be able to connect and go through setup with it disconnected from the centurylink device (other than setting up internet). CANNOT DO THIS....I am officially giving up and throwing the orbi in the lake. I have spent 7 hours on this already. I just need to speak to a real person or maybe have somebody come to my house and show me. Can't even find a phone number anywhere on the century link website to get help...maybe I can find a phone number and speak to a person at Netgear.
- FURRYe38Oct 31, 2021Guru - Experienced User
So you can't access the RBRs web page at 192.168.1.1 after you factory reset it and having it disconnected from the ISP modem from a wired PC connected to the RBR?
