Jsharpmsw
Feb 03, 2022Aspirant
Orbi rbr50
I got a new modem installed by spectrum. Hardwire to my computer it works great. But when I connect my orbi rbr50 back to it, my download speeds completely drop to the point I can't use my wifi for a...
- Feb 04, 2022
What was the brand and model# of the prior modem?
Has a power OFF of the current ISP modem and the RBR for 1 minute then back ON been performed?
Be sure your using good quality LAN cables between the modem and RBR. CAT6 is recommended.
Try a different modem if the prior modem worked. Could be something wrong with this new one.
Feb 03, 2022Guru - Experienced User
Please edit out any Serial numbers and MAC addresses of Orbi devices before posting for security reasons.
Jsharpmsw
Manufacturer Hitron
Model. E31N2V1
Model. E31N2V1
