Sprucan's avatar
Sprucan
Orbi RBR50
Basic question - why is there no secure login when I access my Orbi router? When I try to use HTTPS, it defaults to "non-secure." I don't want to change PW, etc. via a non-secure connection.
What am I missing?
Thanks
  • In the Orbi AX routers there is an option under >> Advanced >> Advanced Settings that's called HTTPS where you can activate https.
    I gues this was also introdcued in the original Orbi as well? I don't currently have access to my RBR50 router, can you please check. 🙂
    • CrimpOn's avatar
      CrimpOn
      Yes. It is on the Advanced Tab, Advanced Settings.
      Web browsers will complain about the SSL certificate being self-signed.  If you click the option to "go there anyway", the browser will remember and not complain again.
      • Sprucan's avatar
        Sprucan
        Web Services Management is there but grayed out.
        I can't click on it to make the change.
