mrsgarfield
Oct 06, 2022Aspirant
Orbi RBR50
Can I access Orbi without using the App? If yes, how can I access it via Safari. Also, can I find out what time a device start using my wifi? Thanks.
CrimpOn
Oct 06, 2022Guru - Experienced User
When you are connected to the Orbi network, open any web browser (including Safari) and access http://orbilogin.net.
The user name is always "admin" and the password is whatever was entered when the router was configured.
See page 20 of the User Manual: https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
mrsgarfield
Thanks. I am in. How can I find out if a device has accessed into my guest wifi?
Earlier today, there is an unknown device "Google Chrome" showed up on my Guest Wifi. I freaked out and blocked it. Then I reset the Guest wifi name and password. Is it too late to see if the Google Chrome device was accessed my wifi?
Thanks for your advice.
