mw1999
Mar 19, 2020Aspirant
Orbi RBR50r2 - firmware V2.3.5.30 - slow download speeds
I have 500 Mbps service from my ISP. Checking my download speed prior to connecting to the Orbi, I get very close to 500 Mbps. After connecting to the orbi and checking the download speed -- it is ...
- Mar 20, 2020
Please mark your thread as solved so others will know.
Enjoy.
mw1999
Mar 20, 2020Aspirant
I have no modem from the isp -- the line comes in direct. I can connect to that line to a computer and get speeds of 500+Mbps. Running a speed test from the orbi app, the speeds are also very high. However a device connected directly to a port off the orbi and the speeds decrease by 50%-80%.
I have not reset and setup from scratch since the firmware update -- I will try that.
I have tried different computers connected directly to the orbi -- the best I get is 50% reduction in speed.
Neither circle, nor armor are enabled.
Mar 20, 2020Guru - Experienced User
Ok, let us know what you see after the reset.
- mw1999Mar 20, 2020Aspirant
Ok, I reset the router and set it back up again.
On my windows machine my speeds are very good. I'm going to set the network back up again and see how it goes. Thank you for your help!
- FURRYe38Mar 20, 2020Guru - Experienced User
Enjoy.
