MartonDotNO
Sep 03, 2021Aspirant
Orbi RBR50/RBS50 - Cannot downgrade firmware
My RBR 50 (router) and my RBS 50 (Sattelite) won't downgrade! RBR 50: V2.7.3.22 - current version RBS 50: V2.7.3.22 - current version ISSUE nr 1: Multiple times a day my RBS 50 losses con...
CrimpOn
Sep 03, 2021Guru - Experienced User
There have been many reports of customers using the Manual Update tab on the Firmware Update page to load previous firmware on the Orbi. During this process, the Orbi will reboot, which causes the web browser to lose the connection. When the router has finished rebooting, the web page has to reauthenticate and get connected again. The steps are normal. What is not normal is the firmware not changing.
Those reports also describe their Orbi systems automatically updating to version 2.7.3.22 again. This puts them back with the problem which caused them to load previous firmware. A vicious circle. There are ways to prevent the autoupdate, either:
- Adding an inexpensive router upstream of the Orbi and having that router block access to the Netgear firmware update sites, or
- Using telnet to change the version number stored in memory so that it does not recognize the new version as 'newer'. This hack has to be reapplied any time the router reboots (a nuisance).
It is an ugly situation for some customers. And clearly worse in your situation if the manual update process does not work at all.
- MartonDotNOSep 19, 2021Aspirant
Hi, didnt know anyone replayed to my post. So thanks and sorry for the late respons.
Ok, so reboot =loose conmnection, makes sense of course.So going forward. do you know the url i need to block for not the router to download the update manualy?
Telnet sounds like an option that will be to advanced for me.Can also add that when this connection breaks with my sattelite i an not even get on the WEB UI on it. So if im wired to the sattlite i can access it with 192.168.1.3, but when this connection issues hits me im not able to do it.
- FURRYe38Sep 20, 2021Guru - Experienced User
- MartonDotNOSep 20, 2021Aspirant
Yes, reset has been preformed and sad to say it didnt resolve it.
Hi again, took the time to look at a video on Telnet enable feature on the Router don't look to be an option here for me. Might have been removed on the newer firmware?
- CrimpOnSep 20, 2021Guru - Experienced User
There appear to be several issues being discussed at the same time:
- A connection issue between router and satellite
I get the sense that this issue was not present before the router updated to V2.7.3.22.
Is this correct?
If so, then manually loading previous firmware might be a temporary solution until Netgear produces new firmware which corrects the problem. - Unable to manually load previous firmware on the router and satellite
- Preventing the router/satellite from automatically updating firmware to V2.7.3.22
Manually loading firmware is best done when connected directly to the router or satellite. i.e. after downloading and unpacking the *.img files for both router and satellite:
- Connect directly to the router (192.168.1.1), navigate to the Firmware Update, Manual Update tab, select the firmware and update.
- Connect directly to the satellite (192.168.1.3) and select Firmware Update from the home screen menu.
Every time I have done this, the manual upload has worked and when the device restarts it has the version that was uploaded. What has been reported in the forum is that the router sometimes notices the available firmware and does an automatic update again. There may be a very small window to prevent this. It will certainly prevent auto-update if the router is temporarily disconnected from the Internet.
There are two options for preventing auto-update:
- Place a router between the Orbi and Internet which blocks access to http.fw.updates1.netgear.com
This can be any old router. Could even be the ISP combination modem/router.
This does create a "Double NAT" condition which interferes with certain applications.
https://kb.netgear.com/30186/What-is-Double-NAT
But it's a choice (a) have no Double NAT and experience problems, or (b) fix the primary problem and live with the consequences of Double NAT.
When access to http.fw.updates1.netgear.com is blocked, the Orbi cannot auto-update. - User telnet to block the Orbi from recognizing that newer firmware is available by replacing the file firmware_version with a bigger number than any possible Orbi firmware from Netgear.
Netgear removed the telnet option from the debug page starting with V2.7.3.22, so if a previous firmware has been installed on the router & satellite, the telnet option should be there.
