MartonDotNO
Sep 03, 2021Aspirant
Orbi RBR50/RBS50 - Cannot downgrade firmware
My RBR 50 (router) and my RBS 50 (Sattelite) won't downgrade! RBR 50: V2.7.3.22 - current version RBS 50: V2.7.3.22 - current version ISSUE nr 1: Multiple times a day my RBS 50 losses con...
MartonDotNO
Sep 19, 2021Aspirant
Hi, didnt know anyone replayed to my post. So thanks and sorry for the late respons.
Ok, so reboot =loose conmnection, makes sense of course.
So going forward. do you know the url i need to block for not the router to download the update manualy?
Telnet sounds like an option that will be to advanced for me.
Can also add that when this connection breaks with my sattelite i an not even get on the WEB UI on it. So if im wired to the sattlite i can access it with 192.168.1.3, but when this connection issues hits me im not able to do it.
Sep 20, 2021Guru - Experienced User
- MartonDotNOSep 20, 2021Aspirant
Yes, reset has been preformed and sad to say it didnt resolve it.
