millim
Jan 15, 2019Aspirant
Orbi RBR50/RBS50 and Connected Devices
House is 2 story split level w/ rear of lower level in the hillside. Approx 4800 sq. feet. Have Uverse 50 Mbps plan today (fastest I can get w/ them) with Arris NVG589 Router/Modem (turned off wifi...
ekhalil
Jan 15, 2019Master
millim wrote:
........ That said, since my speedtests are showing 50 Mbps at each of these devices (when using the added satellites) I'm not sure that's really the issue.
You seem to have good radio coverage. The issue can be in the routing functionality, just a guess. Have you tried to bridge the Motorola NVG589 router and use Orbi in Router Mode?
millim
For a long time I had the Orbi in router mode behind my other router. Apparently a no-no. I haven’t tried bridging as you suggested - that sounds like a good option to try.
