sminervi
Sep 15, 2018Aspirant
Orbi RBR50/RBS50 AP mode disconnection
Hi team,
just got a new RBR50/RBS50. firmware updated to v2.1.4.16, latest on the portal.
the issue is that as soon as i change RBR50 to AP mode i miss the satellite RBS50.
only way to recover ...
Sep 17, 2018Guru - Experienced User
What is the model# of this switch your using?
If the satellite is wired, then Daisy chain needs to be disabled.
The best method I found to get a satellite wired is to reset it, re-add it via wireless, do this near the router. Once the top led on the satellite is BLUE, connect the LAN cable between the router and satellite and give 5 minutes for the top led on the satellite to turn on BLUE. Do a IP address reservation ON the router for the satellite. Save and apply. Turn off the satellite then place in remote location and connect up it's LAN cable there to the satellite and turn on.
sminervi
Sep 18, 2018Aspirant
Again thanks for the answer.
i reserved the IP adrresses as you suggested.
one thing i still don't find is where i have to disable Daisy Chain.
can you point me to the option ?
thanks
ciao
- FURRYe38Sep 18, 2018Guru - Experienced User
Daisy Chain should be under Advanced Tab/Advanced/Wireless Settings.
- sminerviSep 20, 2018Aspirant
thanks a lot.
one more thing i don't understand if possible.
in the Orbi console, im now in AP mode, i see the satellite wired, and 10 devices. All of them are reported as connected to the RBR50, none on the RBS50 .
considerind some of them are in the same room of RBS50 this souds very strange.
is this due to the AP mode ?
how can i test RBS50 is working really?
thanks
- FURRYe38Sep 20, 2018Guru - Experienced User
Yes this is due to AP mode and the network acting all on the same line and seeing everything connected.
