MrToadsWildRide
Mar 29, 2019Guide
Orbi RBR50/RBS50 Firmware Version 2.3.1.44 constantly dropping wifi connections to iphones/ipads
Updated my RBR and 2 RBS satellite (also have 2 RBSK outdoor satellites that did not update) a few days ago. Worked fine until yesterday and now none of our iphones or ipads will stay connected for ...
jsturess
Apr 10, 2019Apprentice
My wifi also still drops but for all devices, see attachment. Today the "connection type" and connected orbi" seem so work, it dosent chage from wifi to wired and so on under connected devices. What I have changed since last time is "transmitt power controll" to 100% for both 2,4 and 5GHz, seems to stable "connection type" but it still drops wifi.
Apr 24, 2019Guru - Experienced User
Have you updated to v48 and done a factory reset and setup from scratch after the update?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Try enabling or disabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Test system with all cameras turned off.
