mzakes
Apr 17, 2022Aspirant
Orbi RBR50/RBS50 no route to host
Model version - RBR50/RBS50 Firmware version 2.7.3.22 I have an issue with my Satellite RBS50. After few hours my network devices connected to the satellite start to report "no internet" or "no ...
Apr 17, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Armor, Circle, Traffic Meter.
- mzakesApr 18, 2022Aspirant
Hi,
the ng router is connect to ZTE H288A. It has double NAT, i tried some time ago to configure PPPoE with vlan id but that was unsuccessful so if needed I do port forwarding.
I have a two story house and 30ft was too much. My NGs could not reach each other in a 6m (20ft) distance if they were placed on two different floors. The distance that I have currently is 4m and they still jump from 5Ghz to 2.4Ghz backhaul on occasion.
w.r.t. factory reset - I did that on satellite and reconfigured internet from scratch (without factory reset of NG router) few days back. The problem still persists
Armor, Circle, Traffic Meter were and are disabled.
The setup is very similar to the one from the link shared. I just did not disable the logs from point 7 and have dynamic (not static) channel setup. I will try to adjust that
