Starstripes
Jul 01, 2022Aspirant
Orbi RBR50v2 - Access to Retail websites
Hi there We are using the Orbi RBR50v2 for our WIFI access. We have noticed that there are some retail websites that we cannot access - it just says unable to connect, and has a blank screen. Is t...
CrimpOn
Jul 01, 2022Guru - Experienced User
Some examples would be helpful.
Does this system have Bitdefender Armor or Parental Controls enabled?
Jul 02, 2022Guru - Experienced User
Also what modem/gateway is it connected to?
Is IPv6 enabled?
Are you using a different dns server? Have you tried a different one?
Try a different DNS Server. Here's a few for ipv4. Also remember to change the ipv6 dns server if ipv6 is enabled
CloudFlare 1.1.1.1 and 1.0.0.1
GoogleDNS 8.8.8.8 and 8.8.4.4
