MarkieMark900
Dec 26, 2020Follower
Orbi RBR50V2 and Nighthawk DC7000
Hi I am currently running the Orbi RBR50 Router with three RBS satelittes from a BT (ISP) Smarthub Router/Modem with the wifii disconnected on the ISP R/M but there is no facilty to use "Modem only...
Dec 28, 2020Guru - Experienced User
Ask you ISP about what is available for a DSL modem that doesn't have a built in router. Since you have the Orbi system already as a router and wifi, you don't need a modem with the same features. Thought the D series modem can be put into modem only mode. This would help with double NAT issues.
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
