RG56
Feb 15, 2024Aspirant
Orbi RBR50v2 loss of internet access
Hi, this is my first post here. After resetting the Orbi router I have lost connect to my internet provider - the suggested network now comes up on my devices as ORBI33, rather than the name of my IS...
- Feb 16, 2024
RG56 wrote:
Thanks for all your help on this, it really is appreciated. I've gone back to configuring my Virgin Hub as the router and disabling the Orbi system for the time being.
The Orbi works well in AP mode. Pretty easy to set up too.
Just connect the Orbi, and only the Orbi, to a PC. (No need to be on line to do that.) Change it to AP mode and then add it to the network from the router.
You'll end up with two wifi networks. When you are happy that the Orbi meets your needs, turn off the router's wifi. With luck that is simply a case of pressing a button.
Shouldn't take more than about 10 minutes.
RG56
Feb 16, 2024Aspirant
Thanks for all your help on this, it really is appreciated. I've gone back to configuring my Virgin Hub as the router and disabling the Orbi system for the time being. I have a couple of wired connections going straight into the Virgin hub and there is only one room with poor wifi now that needs a strong connection - that will have to wait until I can summon up the energy - I've already lost a day's work to this.
I'll try starting from scratch and setting up as if new.
michaelkenward
Feb 16, 2024Guru - Experienced User
