RipmoRider
Nov 02, 2024Follower
Orbi RBR50v2 not seeing latest firmware
I have an Orbi RBR50v2 with one RBS50 satellite. Accessing the router shows that it has V2.7.4.24 installed on both devices and that there is no new firmware available. The netgear site, however, sho...
- Nov 04, 2024
Hello RipmoRider ,
Welcome to the NETGEAR Community!
The most recent firmware for your RBR50 is FW version 2.7.5.4 is an optional but recommended update. To upgrade to FW 2.7.5.4 the user will have to manually update your Orbi system.
Here are some links to guide you through updating your Orbi Mesh system manually:
For step-by-step instructions on how to manually update your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-comPlease navigate to the knowledge based article below for a video reference on the update process:
Best,
Kevin
Community Team
Nov 02, 2024Guru - Experienced User
The Orbi AC series is EoL so NG, I presume removed these models from there Auto Update services.
You can manually update from now on. RBS first, the RBR lastly.
