GilesGibson
Aug 07, 2024Aspirant
Orbi RBR50V2 permanent flashing white light
I have done what I thought was a factory reset on the RBR50V2 unit. I wanted o connect the units ( incl two satellites) to a new network as AP's. The main modem unit has not been able to go beyo...
Aug 07, 2024Guru - Experienced User
So accessing the RBRs web page at 192.168.1.1 with a ethernet connected PC is not working?
If you press the reset button for 15 seconds then release, then give it about two minutes, with the RBR disconnected from the ISP modem, can you get the setup wizard web page to appear in any web browser at all?
GilesGibson
Hi and thanks for replying.
I have been through this loop a few times. I tried it again just in case. The Orbi wifi doesn't appear so unable to connect to it. A cabled connection doesn't get the login screen at all via 192.168.1.1.
Is there a more definitive factory reset on the PCB at all? One that doesn't reply on some software polling the switch etc?
Other ideas and suggestions appreciated.
- FURRYe38Aug 07, 2024Guru - Experienced User
Try a 30-30-30 reset on the RBR.
If this fails to bring up the beginning setup wizard web ui at 192.168.1.1, then possible the RBR maybe faulty and needs replacing.- GilesGibsonAug 07, 2024Aspirant
Apologies for not knowing but what is a 30-30-30 reset?
If it has failed to do a reset and fallen over permanently then that is a real problem. It is out of warranty so it has turned itself into nothing more than an expensive paperweight. Not great.
