GilesGibson
Aug 07, 2024Aspirant
Orbi RBR50V2 permanent flashing white light
I have done what I thought was a factory reset on the RBR50V2 unit. I wanted o connect the units ( incl two satellites) to a new network as AP's. The main modem unit has not been able to go beyo...
GilesGibson
Hi and thanks for replying.
I have been through this loop a few times. I tried it again just in case. The Orbi wifi doesn't appear so unable to connect to it. A cabled connection doesn't get the login screen at all via 192.168.1.1.
Is there a more definitive factory reset on the PCB at all? One that doesn't reply on some software polling the switch etc?
Other ideas and suggestions appreciated.
Aug 07, 2024Guru - Experienced User
Try a 30-30-30 reset on the RBR.
If this fails to bring up the beginning setup wizard web ui at 192.168.1.1, then possible the RBR maybe faulty and needs replacing.
- GilesGibsonAug 07, 2024Aspirant
Apologies for not knowing but what is a 30-30-30 reset?
If it has failed to do a reset and fallen over permanently then that is a real problem. It is out of warranty so it has turned itself into nothing more than an expensive paperweight. Not great.
- FURRYe38Aug 07, 2024Guru - Experienced User
Thanks for this. I have tried it and at least the power LED is flashing red now, didn't do that before. Maybe there is life left in it yet.
I will leave it pondering on life for a while, red power light and white light t the top have been flashing away for 10 mins now.
