jamieglover
Apr 16, 2021Initiate
Orbi RBR50v2 speed from satellites
Hello, I am a mesh wifi novice, so please forgive me if I am failing to grasp any basics! I have an Orbi RBR50v2 router with 2 satellites which has worked well for about a year. I have tod...
Apr 16, 2021Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- jamiegloverApr 17, 2021InitiateMany thanks! I Will get on to my ISP. Very grateful to you.
- FURRYe38Apr 17, 2021Guru - Experienced User
:smileywink:
