WeeFee
Oct 27, 2021Aspirant
Orbi RBR50v2 weak connections
Dear community, I have an RBR50v2 router (wired to my internet service provider modem) and a satellite based upstairs. i still seem to have very weak connections across the house even though ...
Oct 27, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
https://kb.netgear.com/31211/At-what-speed-and-bandwidth-can-my-Orbi-system-transmit-data
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
