skyward1
Dec 11, 2019Apprentice
Orbi RBR50v2 WiFi Connection Drops on Smartphone
Hello, I am a brand new Orbi customer. The wifi stops working for my cell phones (Samsung S9+) when some time passes after a successful connection. The wifi signal icon on the phone shows a exclam...
SW_
Dec 11, 2019Prodigy
skyward1 wrote:...
The wifi signal icon on the phone shows a exclamation mark (!) next to it. When this occurs, there is no wifi operation on my phones. If I turn the wifi off, on the phone, then on, the wifi starts working. It seems to work until you move around the house (but I'm not 100% certain if the same issue occurs when the phone is not moved around).
This implies that the hand off between Router/Satellite might not happen correctly. Given you have wired backhaul, one of the first thing that you can try is to tick Enable Fast Roaming checkbox and hit "Apply". Then start walking around with your phone to see if that resolves the hand off issue between Router/Satellite.
- skyward1Dec 12, 2019Apprentice
I have gone ahead and enabled fast roaming. I will see how things go over the next few days.
Thank you!
sky
- FURRYe38Dec 13, 2019Guru - Experienced User
Let us know how it works out.
skyward1 wrote:I have gone ahead and enabled fast roaming. I will see how things go over the next few days.
Thank you!
sky
- skyward1Dec 13, 2019Apprentice
Thanks for your help, guys, but there is no change.
Also, the famous NetGear support has yet to contact me. I submitted a ticket several days ago.
sky
