skyward1
Dec 11, 2019Apprentice
Orbi RBR50v2 WiFi Connection Drops on Smartphone
Hello, I am a brand new Orbi customer. The wifi stops working for my cell phones (Samsung S9+) when some time passes after a successful connection. The wifi signal icon on the phone shows a exclam...
skyward1
Dec 12, 2019Apprentice
I have gone ahead and enabled fast roaming. I will see how things go over the next few days.
Thank you!
sky
Dec 13, 2019Guru - Experienced User
Let us know how it works out.
skyward1 wrote:I have gone ahead and enabled fast roaming. I will see how things go over the next few days.
Thank you!
sky
- skyward1Dec 13, 2019Apprentice
Thanks for your help, guys, but there is no change.
Also, the famous NetGear support has yet to contact me. I submitted a ticket several days ago.
sky
- FURRYe38Dec 13, 2019Guru - Experienced User
Along with making the fast roaming change, do you apply any of the other suggestions while you wait for NG support to make contact? Sometimes it can be a day or two.
skyward1 wrote:Thanks for your help, guys, but there is no change.
sky
Yes, I have enabled beamforming and mu-mimo, as well as, the exclusive 40MHz, you suggested. I am usuing channels 1 and 48. The NetGear WiFi Analytics app had the best stats with those. For my WiFi PC (on channel 1), it is getting much better speed, but the two S9+ phones had the '!' next to the WiFi icon again.
I am thinking about returning this system to Amazon.
Thanks!
sky
You might go into the RBRs web page and see about assigning a IP address to these phones.
Under Advanced tab/Setting/LAN Setup.
I would forget the wifi profile on these phones, reboot them then attempt to reconnect.
- skyward1Dec 14, 2019Apprentice
I have assigned static IPs for both of the S9+ phones. I also had them forget the wifi, rebooted the phones, and then reconnected them.
Fingers crossed.
Thank you!
sky
