pkaflic's avatar
pkaflic
Orbi RBR5v2 satellite speeds. One at 48 and the other at 7. Reset to factory settings, no change.
I have a Orbi RBR5v2.  When I have one satellites connected it will preform to the same speed as the router.  One I have both satellites connected, one will have the speed of the router...say 48 and the other will only reach a speed of 9 at best.  I have reset the router to factory settings and setup the system from the begining.  No change. Firmware is uptodate.  Looking for a fix as I need both satellites to run at the same speed.  Any help out there?
  • CrimpOn's avatar
    CrimpOn
    Please excuse my question:  Where are you seeing the "7" and "48" values?
    • pkaflic's avatar
      pkaflic
      When I do a speed check
    • pkaflic's avatar
      pkaflic
      When I go out and do a speed check.  These are the numbers I get for down load and up load speed.  What I showed is the down load speed.
      • CrimpOn's avatar
        CrimpOn
        Thanks for the explanation.  I was distracted by the coincidence that "7" is a common 2.4G channel and "48" is a common 5G channel for the Orbi.
        Which Speedtest are you using?  (iPhone, Android, Windows, ?)
