Asi65
Jan 23, 2022Follower
Orbi RBR750 and RBS750 - Unable to see any connected devices to the satellites
Hi,
I have the Orbi RBR750 with two Satellites (RBS750) connected to it. However, When I look at all connected devices, I only see that these are connected to the main router but none to the satellites even though the satellites are much closer to those devices... any idea?
When I look at the Orbi network map - I see the router and satellites - all show green status.
Thanks
Assaf
if you log into the satellite using its ip address, are devices showing as connected on there?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Asi65 wrote:
Hi,
Thanks
Assaf
Any progress on this?
Asi65 wrote:
Hi,
Thanks
Assaf
