orbiuser1975
Dec 29, 2020Apprentice
Orbi RBR750 Backhaul Connections Reported Incorrectly
Just installed a RBR750 router/satellite system. Both the router and satellite have firmware V3.2.16.22_1.4.9. The satellite backhaul connection is via CAT5e through a switch (not direct). Couple of...
- Dec 30, 2020
Please post in Orbi 6 forum
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
FWIW, I have seen posts here (for lesser Orbi systems) that power-cycling the base router sometimes fixes this. But I could be all wrong (I haven't experienced or fixed this myself).
alokeprasad
Dec 30, 2020Mentor
- orbiuser1975Dec 30, 2020Apprentice
Thanks, marked as accepted and reposted in Orbi 6.
- alokeprasadDec 30, 2020Mentor
For a moment I thought that my power-cycling suggestion worked :smileyhappy:
Unfortunately, no, but I did try. Thanks.
