tlcavazos413
Apr 14, 2021Aspirant
Orbi RBR750 Constantly Drops Internet
Ordered the RBR753 which contains 1 router (RBR750) and 2 satellites. Recently the wireless connections started dropping constantly. I am unable to perform any speed tests in the app or through orbilo...
vajim
Apr 14, 2021Master
tlcavazos413 wrote:
Ordered the RBR753 which contains 1 router (RBR750) and 2 satellites. Recently the wireless connections started dropping constantly. I am unable to perform any speed tests in the app or through orbilogin.net. The router (CM1200) does not have any issues as I have had to hard wire to it because the wireless is not dependable at all! Any suggestions? I have the most recent firmware update.
Ordered the RBR753 which contains 1 router (RBR750) & The router (CM1200)
You need to take a closer look at what you're trying to setup. Is the CM1200 a modem or router or both?
- tlcavazos413Apr 14, 2021AspirantI am just trying to setup a reliable wireless internet solution in my house. The CM1200 is just the cable modem. The RBR750 serves as the router.
- vajimApr 14, 2021Master
maybe this will help
https://community.netgear.com/t5/Orbi-AX/Orbi-RBK752-with-Netgear-Nighthawk-CM1200/td-p/1964289
vajim wrote:maybe this will help
and over here is a better spot for your question:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
