EdmondDad
Apr 28, 2021Aspirant
Orbi RBR750 intermittent lost connection
I have a new Orbi RBR750, have had it for about one month or so. Mostly, it works fine, although I haven't sensed any major improvements with this wifi 6 upgrade. Problem: intermittently, when goin...
EdmondDad
The only devices that move around are phones and iPads. And we never, or rarely, stream to a phone or iPad, only stream to stationary devices like Apple TV, Roku, etc. And this doesn't happen EVERY time, but often, if you are looking at something on a browser, email, etc. in one room, then you put your phone in your pocket, go to another room, look at it again, you can see it connected to wifi, but stuff doesn't refresh unless you go to airplane mode, wait a second or two, then take out of airplane mode, and then everything works perfectly. I've never had any trouble on hardwired devices (hardwired to any of the orbi devices), or on a stationary device, only on things that move around, like phone or iPad, occasionally on a windows laptop.
CrimpOn
Apr 28, 2021Guru - Experienced User
Thanks. I do not stream on my mobile, either. The suggestion was as an experiment to see if service got interrupted.
There is an internet standard for "Fast Roaming" that the Orbi supports. https://en.wikipedia.org/wiki/IEEE_802.11r-2008
Pn my older generation Orbi, Advanced Setup, Advanced WiFi Settings has an on/off toggle for Fast Roaming. (This could be one of the things that is different about the AX product line.)
