ViperNY
Oct 09, 2021Aspirant
Orbi RBR750 VPN iPad setup errors
Keep getting "server poll timeout, tryiing next remote entry" I followed instructions, enabled VPN, downloaded IOS file and transfered to iPad. Checked DDNS (NO-IP), verified event log is being redir...
ViperNY
Oct 10, 2021Aspirant
OVPN file,
client
dev tun
proto udp
sndbuf 393216
rcvbuf 393216
push "sndbuf 393216"
push "rcvbuf 393216"
remote XXXXXX.ddns.net 12973
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 0
CrimpOn
Oct 10, 2021Guru - Experienced User
Now I am confused. My old Orbi 'smart phone' ovpn file has only the lines before the certificate begins:
client
dev tun
proto udp
remote xxxx.mynetgear.com 12973
nobind
persist-key
persist-tun
<ca>
None of that buffer stuff. And my 'smartphone' ovpn file contains all of the certificates and keys in the same text file.
There are not separate files for ca.crt, client.crt, and client.key.
Either the 750 Orbi produces a different smart-phone file, or you have the wrong ovpn file.
