plagana57
Nov 28, 2020Aspirant
Orbi RBR750 Wifi 6 Much Slower WIFI than wired internet? 500/302 vs. 945/852. Is this normal?
Set up in my home office. I have a large home, 5,000 Sq Feet 2 floors Orbi WIFI 6 Mesh Model RBR750 Firmware V3.2.16.6 Fios 1 Gig fiber internet plugged directly into Orbi WAN port with CAT 6. S...
Nov 28, 2020Guru - Experienced User
Is your iphone AX supporting?
Most AC supporting devices max out at 400-500Mpbs on 5ghz AC wireless.
plagana57
Nov 29, 2020Aspirant
THank you so much for your comment.
You are correct my IPhone does not support AX, but my point is i feel my WIFI numbers should not drop to under 75/75 at the other end of my house when I have the satellite hardwired to the router and it is postioned directly under the bedroom floor in the basement. Also my dining room 43/22, front porch 11/2,??? is this normal or do I need to work at it a little to get it to increase? Maybe buy another satellite?
- FURRYe38Nov 29, 2020Guru - Experienced User
The distance will cause speeds to drop.
Did you disable the wifi radio on the phone first, then move closer to the RBS, then re-enable the phones wifi radio so it will connect to the RBS? Sometimes phones will keep the connection to the farther signal untill it's force to disconnect then re-connect to find something closer.
Be sure your using good quality LAN cable between the CBR and RBS. CAT6 is recommended.
