Batch48
Sep 27, 2021Aspirant
Orbi RBR850 - SPC/Circle MISTAKENLY activated - Cannot set custom DNS servers?
Hardware reference: One Orbi RBR850 + two synced Orbi RBS850 satellites running Netgear firmware version 4.6.3.16_2.0.51. Windows 10 PC using Firefox v92.0.1 and Chrome v94.0.4606.61 browsers to acce...
CrimpOn
Sep 27, 2021Guru - Experienced User
Is this a "free trial" or an actual subscription?
Did you activate Circle or the new SPC version?
CrimpOn
When you configured the RBR850 after the Factory Reset, was this using the Orbi "app" or using the Orbi web interface (http://orbilogin.net)
I can see how the Orbi app will remember settings. The web interface should come up with Circle/SPC not activated.
- Batch48Sep 27, 2021Aspirant
Following fatory reset I configured the network via the app. I believe that I also deleted the Orbi app and reinstalled the app after the factory reset.
- CrimpOnSep 27, 2021Guru - Experienced User
We Luddites always use the web interface.
I, myself, got into a strange state where I had never activated Parental Controls, but every time I opened the damn app it wanted me to "Complete the configuration". Was like a 10 gallon enema fixing that situation.
Would you recommend that I perform another factory reset on the Orbi devices, delete the Orbi app, use the Orbi web interface to reconfigure the devices and the network, then reinstall the Orbi app on mobile devices?
