Noodles123
Jan 17, 2022Follower
Orbi RBR850 wiring satellites thru switch
Hi - I’m in an apartment building whose walls and floors create significant interference for WiFi. The good news is that I have Ethernet hardwired through much of the house. I have an RBR850 and 4 sat...
CrimpOn
Jan 17, 2022Guru - Experienced User
Noodles123 wrote:
I have a fios modem that is connected to the RBR850. That is then connected to a switch (which is where the Ethernet cords from around the house connect, including to the two satellites). What could cause this?
Could you please describe the wiring in a bit more detail.
Do all those ethernet cables terminate in:
- A patch panel. then ethernet patch cords are used to connect from the patch panel to the switch? or
- into the switch itself (no patch panel)?
While there is no logical reason why connecting satellites through a switch should have any effect on the satellites, if there is a patch panel, would it be possible to bypass the switch and cable directly from the patch panel to the Orbi 805 ethernet ports?
