ElCapo's avatar
ElCapo
Luminary
May 12, 2018
Orbi RBR/RBS50 2.1.4.10 Loses Ethernet Wired Satellite
Hi all
I have an RBK53 setup running in AP mode that was working reasonably well on version 2.1.3.4 with wired Backhaul to both satellites.
in fact, recently it had been working so well, with no drops at all for a long prime I thought I would login and see how it looked.
i noticed straight away that I had ‘lost’ both satellites and they were showing as normal connected devices.  I logged into them individually and noticed that they still had connected devices so were apparently operating as additional access points.
i then realised that the router had auto upgraded to 2.1.4.10 but the satellites were still at 2.1.3.4.
So, big question, is everything actually still working as it should?  Does the satellite need to show as a satellite to work properly?  Should I manual update the satellites to 2.1.4.10 or do I run the risk of messing it all up?
i like that I am getting good performance but I also like things to work as designed.
cheers
1 Reply
