dnh3155
Feb 26, 2019Tutor
Orbi RBR/RBS50 Firmware Updates
I just did a firmware update to 2.2.1.210. No matter where I go in the app, it says that this is the latest version. I read that there is a new firmware version, and that I have to update to 2.2.1.2...
Feb 26, 2019Guru - Experienced User
Please be patient while NG handles the new FW. It was posted and also v212 was needed to update the RBR to v32 as well. Changes are being made so keep an eye on the forums and the download site. Some system may have updated automatically as well. Keep an eye on your systems.
dnh3155 wrote:
I just did a firmware update to 2.2.1.210. No matter where I go in the app, it says that this is the latest version. I read that there is a new firmware version, and that I have to update to 2.2.1.212 to get it. Obviously, I’m two updates behind. How do I get to the latest?
dnh3155
Mar 09, 2019Tutor
I am having trouble updating rbr50/rbs50 to latest version. I have tried to load 2.2.1.212 on satellites first through orbilogin manual, but can’t do it. Obviously, I’m missing something.
Thanks
- FURRYe38Mar 09, 2019Guru - Experienced User
Satellites don't need v212, they can go directly to v32 first. Upgrade the satellites first. When those are finished, upgrade the RBR to v212 then v32.
If you need to factory reset the RBS re-sync. then have a wired LAN PC connected to the satellite and update the FW there.
Thanks
- CrimpOnMar 09, 2019Guru - Experienced User
Thanks
Although the satellites (apparently) do not require an intermediate update to the "212" release, Netgear provides 212 firmware for the satellites, so I applied it to my satellite "just for the heck of it."
"orbilogin.net" will return the IP address of the router, not the satellite. To do a manual firmware update on the satellite, I connect to the IP address of the satellite and select the "Firmware Update" menu option. The IP of the satellie(s) can be found on the "Attached Devices" page. Satellites appear at the top.
- FURRYe38Mar 10, 2019Guru - Experienced User
Good to know. Something users can follow. I would avoid the intermediate version on the RBS. Go directly to v32 from v210.
