dnh3155
Feb 26, 2019Tutor
Orbi RBR/RBS50 Firmware Updates
I just did a firmware update to 2.2.1.210. No matter where I go in the app, it says that this is the latest version. I read that there is a new firmware version, and that I have to update to 2.2.1.2...
dnh3155
Mar 09, 2019Tutor
I am having trouble updating rbr50/rbs50 to latest version. I have tried to load 2.2.1.212 on satellites first through orbilogin manual, but can’t do it. Obviously, I’m missing something.
Thanks
Mar 09, 2019Guru - Experienced User
Satellites don't need v212, they can go directly to v32 first. Upgrade the satellites first. When those are finished, upgrade the RBR to v212 then v32.
If you need to factory reset the RBS re-sync. then have a wired LAN PC connected to the satellite and update the FW there.
Thanks
