RWCPacific
Jun 23, 2019Guide
Orbi RBR/RBS50 Firmware Updates
Hi, Does anyone have experienced problems downloading the latest Orbi Firmware 2.3.1.60? I downloaded the firmware on my computer. When I opened the downloaded folder, there are two files: RBR...
RWCPacific
Jun 23, 2019Guide
Hi CrimpOn,
Thank you for the advice. But how do I change the disc burning location? Right now it is set default to my DVR drive and I can't change it. Netgear is making upgrade a lot more complicated.
Thanks,
Peter
CrimpOn
Jun 23, 2019Guru - Experienced User
When I get files from the internet, the box that pops up asks if I want to (1) Open the file with Windows Explorer, or (2) Save the file to disk. I always click the button "Save to disk", which means the file gets download to my "Downloads" folder. I've attached a screen shot of (a) the Netgear prompt for one of the two files (router & satellite are separate), and (b) where I change from "open" to "save."
I forgot to mention that the recommended practice is to update the satellite(s) first and then the router.
- RWCPacificJun 23, 2019Guide
Hi CrimpOn,
I should mention that I am using Windows 7. When I was downloading the file, I did not get a prompt to where to save the file. The downloaded folder is automatically saved to my download folder. When I opened the folder, there are two files in the folder. When I clicked on the disc image file, I am prompted to burn to a disc. I've attached a screen shot of the process. Please let me know what I am not doing right.
Thanks,
Peter
