RWCPacific
Jun 23, 2019Guide
Orbi RBR/RBS50 Firmware Updates
Hi, Does anyone have experienced problems downloading the latest Orbi Firmware 2.3.1.60? I downloaded the firmware on my computer. When I opened the downloaded folder, there are two files: RBR...
RWCPacific
Jun 23, 2019Guide
Hi Furry,
I have V2.3.1.44 installed. I had also tried downloading using iOS app but also no success.
Thanks,
Peter
Jun 23, 2019Guru - Experienced User
Ok, just making sure you were not using old v1 FW.
Yes just download the v60 FW files for the RBR and RBS, unpack the .zip file. Just use a web bowser and log into the RBR and use the FW update to manually select the .img or .chk files to send to the RBS first, then manually select the file for RBR lastly. Manual FW update is preferred.
