AIRgauge
Mar 10, 2020Aspirant
Orbi RBR/RBS50 not syncing and connected devices not showing
I'm currently running firmware version 2.5.1.8 on both the router and the satellite. Up until recently they were working reliably and the system has been great. Two things may have affected that and ...
Mar 10, 2020Guru - Experienced User
AIRgauge wrote:I'm currently running firmware version 2.5.1.8 on both the router and the satellite. Up until recently they were working reliably and the system has been great. Two things may have affected that and I'm not sure which. We recently added a Ring doorbell to our home network and it doesn't stay connected consistently. We also had a recent very brief power outage and now the satellite doesn't sync with the router, and the connected devices don't show up. They are connected and do function, but the backhaul status shows as disconnected so connections do sometimes drop. I can see the list of devices that have permission to be on the network, but they don't show up as connected. The number of connected devices shows as anywhere between 1 and 5 and varies from time to time.
I've seen other users with similar problems where the solution seems to be to manually update the firmware to the version I'm running. Not sure what to do to fix this?
- AIRgaugeMar 10, 2020Aspirant
What is the Mfr and model# of the ISP modem the NG router is connected too? CICSO DPC3849V - provided by my cable provider and our cable also runs through it.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router30 feet, separated by one floor, and always worked perfectly until now. When I plug the satellite in, it shows a blue circle after it connects to the network, but does not sync.
Any Wifi Neighbors near by? If so, how many?I have tried changing channels as you described but no luck. We have 9 wifi neighbours nearby.
Tried this - it didn't help.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Don't have Armor or Circle enabled, but will try the others.
- FURRYe38Mar 10, 2020Guru - Experienced User
Seems that you may have a ISP modem with built in router and wifi.
Do you know what mode the modem is working in? Router or Bridged?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry removing the RBS from the RBRs web page. Then factory reset the RBS by pressing the back reset button for 15 seconds then release. Once the top ring LED slowly pulsates WHITE, press the black sync button on the RBR then on the RBS. I would do this with the RBS in the same room as the RBR. If you get it sync'd, then place back in remote location.
A reset of the RBR maybe needed as last resort.
- Retired_MemberMar 10, 2020
FURRYe38 wrote:Seems that you may have a ISP modem with built in router and wifi.
Couple of options,
How do you explain...." Up until recently they were working reliably and the system has been great.?"
