AIRgauge
Mar 10, 2020Aspirant
Orbi RBR/RBS50 not syncing and connected devices not showing
I'm currently running firmware version 2.5.1.8 on both the router and the satellite. Up until recently they were working reliably and the system has been great. Two things may have affected that and ...
Mar 11, 2020Guru - Experienced User
What happens if you disable Daisy Chain?
numetheus wrote:
Updated again to the new version. Yep. Problem with the firmware. This time it is only recognizing 7 devices. I should have 19. Confirmed that all of my IP cameras are available, and none showing in the device list. I have two devices wired to satellite and the device list for it shows as blank.
numetheus
Mar 11, 2020Aspirant
Factory reset was performed directly after the first upgrade. Re-configured from scratch and tested for a while and rebooted router and satellite. Confirmed it did not work after leaving devices off then activating some time after everything was powered on. Did not recognize devices. During one test, the satellite was flagged as down despite no lights and the computer physically connected to satellite was online and functioning. If it was down, computer would not work. I have no WiFi card. Downgraded and performed the same test. Devices showed up after refresh and immediately recognized all 19 devices after allowing time for them to re-connect. Working. Performed upgrade and tested again. Same result as broken state. Only 7 devices recognized. Physically unplugged satellite. Page still shows the satellite is good after a while despite being unplugged. It’s not updating.
I do not see how another factory reset will yield different results because a factory reset was performed after the first upgrade to new version. Although I will try it anyways to settle this.
- AnonymousMar 11, 2020
numetheus wrote:
I do not see how another factory reset will yield different results because a factory reset was performed after the first upgrade to new version. Although I will try it anyways to settle this.it won't
leave your FW alone
