AIRgauge
Mar 10, 2020Aspirant
Orbi RBR/RBS50 not syncing and connected devices not showing
I'm currently running firmware version 2.5.1.8 on both the router and the satellite. Up until recently they were working reliably and the system has been great. Two things may have affected that and ...
NJC1
Apr 09, 2020Aspirant
Has anybody found a solution to this. I thought everything was working and moved the satelite, reconnected with the blue ring...
Just found a device near the satelite was showing as out of range, checked the satelite on the webpage to see whilst it is conencted, the backhaul is not.
I haver the satelite on the same desk as the base now so i could try and fix this easily... not luck
Tried the steps others have done too without success except for reverting to an earlier FW version. Not sure how to do that.
- Retired_MemberApr 09, 2020
NJC1 wrote:Has anybody found a solution to this. I thought everything was working and moved the satelite, reconnected with the blue ring...
Go to downloads and enter your model number
