OrbiJes
Apr 10, 2020Aspirant
ORBI RBR/RBS50 sporatic latencies between hosts on the same wifi lan FW V2.5.1.8
lately connectivity has been not so smooth, i started noticing periodic short hangs using remote screens between computers on the same wifi lan at home. AT&T Wifi also gets pretty bad receptions, aud...
OrbiJes
Thanks much! The command on mine showed the following line with "rate"
"backhaul phytxrate" : "1733",
"backhaul phyrxrate" : "1560",
May i assume these numbers look healthy?
Thanks!
OrbiJes
I am also seeing some abnomalies.
On IOS app, both RBR50 and RBS50 were shown with green status and connected. In the web UI, however, shows connected satellite = 1, backhaul status "Disconnected"
Given satelliteinfo wifi command returned stats and IOS app is shown with green status, i am guessing this would be a Web UI bug?
