Dummi's avatar
Dummi
Orbi RBS 40v
How can i flash new FW on an orbi Satellit seperatly without Router?
  • plemans's avatar
    The RBS40V has extender mode or orbi mode. Which one needs updating?
    If you don't have a orbi router, I'd imaging you're using it in extender mode. you can log into it as the manual describes to update it.
    And if its in orbi mode, I think their default ip address is 192.168.1.250 to access it (have to be connected to it).
    • Dummi's avatar
      Dummi
      Hello!
      Thx for your reply. The rbs40v is a part of a rbk50v system. I have update the Rbk 50.
      After updating , the RBS 40v was not found. I have no connection to that devise. In the orbilogin or orbiapp there is no Devise shown. Ethernet connection between  Router and Satellit shows the same result. The rbs40v flashing only white, hours for hours. If i connect it seperatly with my pc with an Ethernet cable it was shown for a view seconds as unknown Network without adresses. I think the Firmware is coruppted. Is there a way to flash only the Satellit with new FW. I heard about FTP Client to do that at the Router.
      Excuse by bad english.
      Greetings from Germany
