jhasbrook
Jul 26, 2017Follower
Orbi RBS 50 satellite will not stay connected to router, even when in the same room.
I got my Orbi system in January of 2017 and it has worked flawless up until this last week. Now the satellite Orbi will not stay connected to the router for more than 1 minute, even when in the same...
DarrenM
Aug 04, 2017Sr. NETGEAR Moderator
Hello Nickburns
Yes if you are willing to work with us send me a PM with your name, email and phone number and I will get you in contact with support. And Anyone else that is willing to work with support on this issue.
Thanks
DarrenM
- XavierCAug 28, 2017Tutor
Any progress on this issue ?
Do you still need help ?
- DarrenMAug 30, 2017Sr. NETGEAR Moderator
If you tried to reset the satellite and resync also make sure its on the same firmware as the router. If that has not worked I would suggest contacting support.
http://www.netgear.com/support/contact.aspx
DarrenM
- XavierCAug 30, 2017Tutor
Been there, done that. Tech support doesn't help, it just reconnect your satellite before loosing it again....
What is needed is an acknowledgement and FW fix from netgear. (or at least a date for it)....
- bhart0531Mar 01, 2018Star
I’ve already worked with support for hours and no resolution. I can’t afford to deal with a non working system for my business, so had to go another direction.
How do we get compensated for a system that no longer works and is past return policy?
- SpoilageAug 21, 2018AspirantHave the same damn problem as everyone else... satellite that once worked now will not connect. Have a solid magenta light. Sucks that Netgear does not care!
Eero, here I come!!
