Coffman's avatar
Coffman
Follower
May 12, 2024
Orbi rbs10
I think I was misinformed, I just signed up with AT&T fiber and was told to get the Orbi satellites to extend the WiFi. Do I need an Orbi router as well?
  • CrimpOn's avatar
    CrimpOn
    This depends on exactly what equipment AT&T fiber installed (product number from the case).
    In 2024, it would be really unusual for AT&T to recommend this ancient Netgear technology rather than a more modern WiFi system that supports at least WiFi6. (The Orbi "10" product supports only WiFi5.)
    AT&T's fiber web site mentions a number of AT&T WiFi products:
    https://www.att.com/support/article/u-verse-high-speed-internet/KM1011652/
    Where did this advice come from?
  • michaelkenward's avatar
    michaelkenward
    Orbi satellites are designed to work with Orbi routers. The RBS10 usually pairs with an RBR10.
    On its own, the RBS10 is not much use.
