Orzbi
Jan 21, 2021Follower
Orbi RBS20 connected to RBR50 lags when connecting to a new site
I have connected a RBS20 Orbi satellite to my existing Orbi network comprising of a RBR50 Orbi router and RBS50 Orbi satellite. Devices that are connected to RBR50 and RBS50 respond fast as expe...
Jan 22, 2021Guru - Experienced User
What Firmware version is currently loaded on the 50 and 20 series units?
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Try disabling:
